1963 headlight switch - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5330
    The dimmer function on my 1963 095 switch just failed. Was working fine, then nothing. I'll remove it and clean everything with acetone, ( the rheostat ), then reinstall.
    Anything else I can do?
  • Michael G.
    • November 12, 2008
    • 2157
    Re: 1963 headlight switch
    You could Pray, I guess, the repros are absolute crap . Good luck
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11334
      Harry, The rheostat likely broke open just after the rivet.
      You can clean the broken piece and use silver solder to reattach it to the rivet.
      When you get it out take it apart and take a few photos of the rheostat.
      Rich
      • Harry S.
        • July 31, 2002
        • 5330
        Rich
        Thanks, I'll pull it when I get back from Tucson and post pictures, if the temperature in my garage gets above 50 degrees.
        I have an NOS 095 sitting in a box ready to install.
        When I turn it to full-on, that function works.
        • Harry S.
          • July 31, 2002
          • 5330
          Rich, finally got to work on the switch today. I decided to try it again before I pulled it apart.
          All worked fine? I am at a loss? I'll leave it alone for now.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            Harry, It could have been a bit of carbon on the rheostat or the contactor and it cleaned itself up.
            Before, did the dash lamps work full bright(knob full CCW)? If not, the INSTR fuse clips may be corroded and intermittent.
            EDIT...Ignore last question, I reread your earlier post and that works.
            Time will tell I guess.
            Rich
