Any suggestions on how to preserve all electronic functions if indoor judging facility requires that you disconnect the battery per the local fire marshal? Doing some Sportsman entries in the future at indoor events. Checked out Battery Memory Saver option. These rely on 9 volt batteries with a 2 hr max life. Any thoughts? Thanks in advance for replies.
Battery disconnect and C-7s
Lynn Skipper 62393
1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.Tags: None- Top
Re: Battery disconnect and C-7s
I've never used one if these, but it's designed for your intended use. I'm not clear why hooking this up is safer than using the car's battery, but the vendor claims it's fire marshall friendly.
Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Thanks Mark. A little too costly for me. I'm curious what C/5 thru C/8 owners are doing for judging events that are completely in doors and over night to meet the Fire Marshal disconnect requirement.Lynn Skipper 62393
1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.- Top
I just have not disconnected my c8 battery when I have had it inside. I didn't do the c7 either. C8 is a bit easier to disconnect as you can get to the battery in the frunk than in the c7 at the back. If FM is going to be real picky on disconnect, I just will not put my car inside. So far has not been a problem.- Top
+1I just have not disconnected my c8 battery when I have had it inside. I didn't do the c7 either. C8 is a bit easier to disconnect as you can get to the battery in the frunk than in the c7 at the back. If FM is going to be real picky on disconnect, I just will not put my car inside. So far has not been a problem.
Why I don't put my car inside - just avoid the problem.
Dave
p.s. Situation with battery cut-offs in any case, regardless of year.
Good: keep you from a wiring problem becoming a catastrophe.
Bad: keep you from knowing you have a wiring problem.Judging Chairman Mid-Way USA (Kansas) Chapter- Top
Thanks for your reply Dave. As a usual Sportsman entry, most times, we are relegated to parking outside. So we'll see how things go in French Lick this summer.
LynnLynn Skipper 62393
