Question on Parking brake part - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    Anyone familiar with this part in the link below? Can't seem to corroborate use/existence of this part anywhere but Doc. Am rebuilding my park brake assembly. Can't seem to see one in there currently. If this is a correct part any info on how/where it mounts?
    Keith
    1967-1982 Corvette Parking Brake Front Cable Nylon Block Genuine GM 14033720 NOS CAVEAT EMPTOR: real deal GM. Very Limited supply. NOTE: does one car. 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Keith M.
    • January 17, 2021
    • 695
    Re: Question on Parking brake part
    Thanks for the info
    • Owen L.
      • September 30, 1991
      • 894
      Originally posted by Keith Michaud (67636)
      Thanks for the info
      I deleted my comment because I realized I was wrong about where on the car this guide is supposedly used. The DocRebuild part is somehow used in the brake pull handle cable (not the rear cable that I initially thought) but I can't find it or the '67-'81 part (3897439) above it. I've looked in both '67 and '72 assembly manuals but don't see anything listed as a guide or looking like a guide other than the previously mentioned horseshoe clips.
      • Owen L.
        • 894
        I think I found it... but I've been mistaken before...
        The '78 assembly manual shows a detail of the handle assembly - view B. It appears a block is illustrated like what DocRebuild shows. It wouldn't have been called out separately if installed as an assembly with the handle. Perhaps the parts illustration book shows it.
        • Keith M.
          • January 17, 2021
          • 695
          There ya go. I forgot to ck illustrated parts catalog but will when I get home. I did ck 69 AIM but I often forget to look at view callouts.
          • Keith M.
            • January 17, 2021
            • 695
            [ATTACH=CONFIG]115964[/ATTACH]
            just checked 69 AIM...no View B.. will pull my handle assebly apart soon. see what i learn then.
              • 43288
              [ATTACH=CONFIG]115963[/ATTACH]
              Owen------
              The original 1967-81 guide, GM #3897439, was discontinued in July, 1987 and replaced for SERVICE by the 1982 guide, GM #14033720. The latter was discontinued without supersession in January, 1993. That's 30 years ago!. I'm surprised the Doc still has any left.
              As I recall, possibly falsely, this guide is within the parking brake handle assembly. The 14033720 will work just as well as the 3897439 and no one will ever know the difference.
              • Keith M.
                • January 17, 2021
                • 695
                Owen------
                So would 33720 be correct for 1969 as a service replacement?
                  • 43288
                  Keith------
                  Definitely YES.
                    • 43288
                    Keith------
                    The guide can be seen in "View B" of the AIM page you included. It is part of the handle assembly and one of the few parts once available separately from GM.
                    • Keith M.
                      • January 17, 2021
                      • 695
                      Keith------
                      Hi,
                      That page that was posted that you reference was from 77 AIM and originally posted by Owen There is no View B in my 69 AIM but I did just unbolt the handle in my 69 and indeed that little plastic retainer is in there. Not sure it is a wear item but I got one from DOC...well...just cuz it is NOS which won't be around forver and not too pricey. And who knows..once I pull it out of there may want to replace it based on what I see.
                      Keith
                        • 43288
                        Hi,
                        Keith
                        Keith------
                        The parking brake lever assembly was basically the same from 1967 through 1982 and all are functionally interchangeable. The only differences involved minor trim differences on the lever handle.
