69 A/C Harness Routing Over Evaporator - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    Can anyone provide a picture of the correct routing/orientation of the A/C harness over the evaporator, around resister, please. My original harness was hacked up a bit so don't trust it and having trouble getting the new harness to lay in the way the assembly manual seems to want it to go.
    Thanks in advance,
    Jack
    Jack Ottofaro
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: 69 A/C Harness Routing Over Evaporator
    Jack,
    Attached are 2 pictures of the harness on my 69. This has never been removed from the car and is original. I hope you can see what you need since it is hard to see let alone photograph.
    Jeff
    • Jack O.
      • July 31, 1996
      • 525
      Perfect. Thanks Jeff!
      Jack Ottofaro
        • 15599
        Jack
        I recall John Hinckley stating that in St Louis they warmed thee harnesses under heat lamps just before installation in order to make them more flexible. Knowing the weather in St Louis I suspect this was a winter practice and was not needed in the Summer.
        Be sure not to overdo it if you heat the harness. Too much heat will not be better.
