Jacking up C3 Front end or rear end in "one Shot" - NCRS Discussion Boards
  • David H.
    • June 30, 2001
    • 1523
    Re: Jacking up C3 Front end or rear end in "one Shot"
    Originally posted by Keith Michaud (67636)
    This is one I have heard but truly do not understand. The body is mounted to the frame in a number of places. The frame is a strong steel structure supporting the body. ....
    Keith
    Not so strong.
    C3 Targa Top originally was to be a single piece. Tests found unless car was absolutely on flat ground tops would not install as frame/body twisted.
    A redesign was required. Result: two piece Targa - with center support from windshield header to rear bow - added necessary stiffness.
    Redesign and production of two piece Targa top took time. For that reason, (I remember) in 1968 first ~12,000 cars were convertibles.
    Dave
    Judging Chairman Mid-Way USA (Kansas) Chapter
    • Kenneth B.
      • August 31, 1984
      • 2087
      I am talking about a 4 point lift not a ramp lift. Trust me I saw it happen on a C-2. The C-3'S even had a pin & receiver in the top of the door to help stiffen the convertible up.
      • Keith M.
        • January 17, 2021
        • 666
        Originally posted by David Houlihan (36425)
        Keith
        Not so strong.
        Dave
        Disclaimer...I am an engineer and eternal sceptic. I still think there is more urban legend to this one and technical details are critical. Do you recall where you heard/saw the targa top design thing? It would imply part of the assembly line was not flat and resulted in twisted frame going down the line.
        Further, not saying if you lift one corner the frame won't "twist"...the question is by exactly how much?? And to the don't open the doors point...the rear of the door is not locked into place preventing front to rear lateral play to some extent when closed. I am not saying all of this is a total non-issue...just think it is very overblown most of the time. If one has the car on four well placed jack stands...not much different than being on 4 wheels.
        late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
        • Mark E.
          • April 1, 1993
          • 4531
          That's not my experience with C2/C3. Door gaps change enough to see when on jack stands, and often the latch becomes misaligned enough to feel when latching or unlatching the door. Think about it... there's over 1,000 pounds of engine and other stuff cantilevered beyond the front jack stands, enough moment to cause deflection.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Leif A.
            • August 31, 1997
            • 3626
            And, therein, lies the difference between the car being on the ground (on it's tires) vs the car being in the air on jack stands with all that weight hanging/sagging down...simple physics.
            Leif
            • Timothy B.
              • April 30, 1983
              • 5183
              Same sag in the rear of the frame if not properly supported.
              • Kenneth B.
                • August 31, 1984
                • 2087
                [QUOTE=Keith Michaud (67636);928828]Disclaimer...I am an engineer and eternal sceptic. I still think there is more urban legend to this one and technical details are critical. Do you recall where you heard/saw the targa top design thing? It would imply part of the assembly line was not flat and resulted in twisted frame going down the line.
                Further, not saying if you lift one corner the frame won't "twist"...the question is by exactly how much?? And to the don't open the doors point...the rear of the door is not locked into place preventing front to rear lateral play to some extent when closed. I am not saying all of this is a total non-issue...just think it is very overblown most of the time. If one has the car on four well placed jack stands...not much different than being on 4 wheels.[/Q
                So why did GM go to the trouble to put pins & receivers in the doors then. I will buy your story if the jack is under the engine.
                • Keith M.
                  • January 17, 2021
                  • 666
                  In either this thread or another I mis-stated where my jackstands are located. Two are under the frame directly in front of the rear wheels. Other two are under the front crossmember spread as wide as possible. Now I know...some might take issue with the crossmember not being an integral welded part of the frame..but...
                  • Mark E.
                    • April 1, 1993
                    • 4531
                    #24
                    I often place jack stands under the frame horns (locations shown in the service manual) or under the front shocks (not shown in the manual). Either causes less frame flex than the side rails; under the front shocks mimic load from the tires.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
