67 front frame horn shim marks - NCRS Discussion Boards
  • Doug M.
    • January 1, 1991
    • 68
    Have 3 tack welded shims plus one additional ( loose) shim at the front of the frame
    The welded shims were there at the time on the unrestored, original frame to the car, in 1990
    For judging purposes, do I apply 4 or 1 chalk marks?
    Thank-you for any replys
    Doug
  • Bob R.
    • June 30, 2002
    • 1595
    • Mark F.
      • July 31, 1998
      • 1595
      Re: 67 front frame horn shim marks
      Originally posted by Doug McClure (18547)
      Have 3 tack welded shims plus one additional ( loose) shim at the front of the frame The welded shims were there at the time on the unrestored, original frame to the car, in 1990 For judging purposes, do I apply 4 or 1 chalk marks? Thank-you for any replys Doug
      Hi Doug,
      Interesting.
      FYI John Hinckley's C2 Assembly Process presentation says the following for the 2nd position on the Frame Upside Down Line (FUDL):
      Cycle clamps, observe plunger readings and mark shim count on frame side rail, rivet upper and lower ball joints to front control arms...etc.
      He goes on to say at the 1st position on the Chassis Line (after it's flipped over from the Frame Upside Down Line):
      "Apply locating fixture and arc-weld #2 body mount brackets to frame on convertibles, and weld required shim pack on front frame horns at the radiator support mount locations."
      I would assume the "FUDL plunger" readings he's referring to would have indicated 3 shims in your case - welded on after the frame was flipped (so they wouldn't fall off).
      PS - there are no other assembly steps where he indicates additional free-shimming for the radiator support mounts, but who knows ?
      Obviously, this is not a good answer for you - hopefully a C2 chassis judge will chime in...
      thx,
      Mark
