Snap ON Model #YA 271 Battery Tester Usage - NCRS Discussion Boards
  • Larry E.
    • 1677
    Larry
    LT1 in a 1LE -- One of 134
  • Thomas S.
    • February 7, 2016
    • 617
    Re: Snap ON Model #YA 271 Battery Tester Usage
    My suggestion is to ask Restoration Battery directly. They used various brands and chemistry types in those batteries and they would have the correct answer based on serial number on the battery. Short of that (no pun) you might have a warranty issue.
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • Larry E.
      • 1677
      Thomas>Thanks for the reply but AFAIK Restoration Battery has closed and no contact. Anybody else that has tried
      or not tried to put a "Battery Load Test" on one of these smaller type batteries?? Larry
      Larry
      • David H.
        • June 30, 2001
        • 1526
        Larry
        My digital (non Snap-On) battery tester requires user to input battery type (AGM/lead-acid/etc) and Cold Cranking Amps (CCA) into tester in-order to run the evaluation.
        Without first opening up your battery enclosure, and determining just what battery (type/CCA) you have inside, I don't see how you can run an evaluation with any tester.
        How old is this Snap-On unit?
        If unit is from the "lead-acid" only era, and internally you have a more modern battery type, then seems to me you can't trust any results.
        Dave
        Judging Chairman Mid-Way USA (Kansas) Chapter
        • Larry E.
          • 1677
          Originally posted by David Houlihan (36425)
          Larry
          Dave
          Dave>Thanks for the reply. My guess is around 1995 or so. Bought direct from the Snap On truck/guy that use to visit our
          place of work every week or so. I do remember it was very expensive but the quality looks very good. If no replies come back
          that it is safe to use on smaller restoration batteries I WILL USE CAUTION AND NOT USE IT ON THAT TYPE OF BATTERY.
          THANKS>LARRY
          Larry
          • Dan D.
            • November 5, 2008
            • 1323
            Larry, I'm not sure, but most of these replacement batters cannot withstand a dead short. The very high current can explode the battery - the internal resistance of the battery is high enough to cause overheating. Most rechargeable batteries, other than lead-acid, have their maximum discharge rates specified and they are generally not that high. I would not use it.
            Dannn
