Delco Freedom Battery Series - 1978-80 - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4105
    While Corvette added power options during the later-model C3 years, alternator amperage was chased to accommodate battery capabilities. Base was a 42-amp alternator that called out the R87-5 battery with 430 CCA, but heavy-duty requirements increased from 61 to 63 (calling out the heavy-duty R89-5 battery and 465 CCA) and later a 70-amp alternator called out as K73. It was in 77-78 when the rear window got the C49 "electro" defogger while vehicles were loaded up with power options.
    The 3rd edition of the 78-79 TIMJG lists the K73 alternator but does not specifiy a matching battery part number but does reference 465 CCA, which I assume is the R89-5 model. It also lists a 540 CCA and no reference to a battery model number.
    Anyone have an old Delco Freedom Battery order guide that might list these numbers and their applications?
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11367
    Re: Delco Freedom Battery Series - 1978-80
    Tom, Unsure if this will help but the 1978 AIM shows the GM part# for the batteries with UA1. Maybe you can use those to cross reference to the Delco numbers.
    • Tom R.
      • June 30, 1993
      • 4105
      It was the addition of the 63 amp alternator
      Tom Russo
      78 Pace Car L82 M21
      00 MY/TR/Conv
