Steering coupler rivets - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    The ground strap on my 63 steering coupler broke. I have a spare ground strap, but to install it I need to remove a rivet.
    Anyone know of a source for just the rivets. Trying to avoid buying the entire kit for one rivet.
  • David B.
    • March 1, 1980
    • 690
    Re: Steering coupler rivets
    Airparts Inc is your best source for aircraft and Airstream aluminum. We specialize in aluminum sheet and coil in 2024T3, 6061T6, 5052, and 3003. We a
    • Mark M.
      • October 21, 2008
      • 343
      Harry, I checked a rivet set from Paragon I have here for a 65 tele rag joint and it looks like the same rivet in a non tele joint which holds the ground strap without taking it apart. It has a 7/16 dia. step than a 5/16 dia. step under the flat head. Part # 10119k 7.00 a set.
