Upper Brackets for Spark Plug Wires on C2 Crate Motor - NCRS Discussion Boards
  • Rob M.
    • April 17, 2014
    • 44
    I am still working on the integration of a base 350/290 hp crate motor into my base model 1963 convertible [came with 250 hp and no power steering, AC, etc.]. I am using an "old style" tach drive distributor with points.
    I have installed a spark plug heat shield kit which included the lower chrome "V" shields and the two lower brackets for the plug wires that attach to the rear of the block [GM part numbers 3744405 and 3728953 per AIM sheet]. My question is whether or not I need the two upper support assemblies for the plug wires or can the wires run directly from the lower brackets to the distributor cap? The upper support assemblies that I am referring to
    [GM part numbers 3826072 and 3826071 per AIM sheet] attach near the intake manifold/cylinder head. Also, are there different wire supports that would work better?
    Rob
    • 43211
    Re: Upper Brackets for Spark Plug Wires on C2 Crate Motor
    Rob
    Rob------
    Yes, you should use the upper supports and grommets regardless of whether this is a radio equipped car (i.e. with RF shielding) or not.
    • Rob M.
      • April 17, 2014
      • 44
      Thanks Joe ---- appreciate your ongoing guidance!
