64 Left Vertical Ignition Shield - NCRS Discussion Boards
  • Ron L.
    • July 31, 1998
    • 111
    There is a hole at the bottom rear of the shield (pic attached). Does this attach to the wire loop in the same location with a wing stud? Parts supplier has been no help on this question - working on a car which has had lots of modifications, and my wire loop may be from another SBC applications.
  • Don H.
    Moderator
    • June 16, 2009
    • 2268
    Re: 64 Left Vertical Ignition Shield
    moving this to the Technical Discussion Board. The Help,Support forum is for questions about using the website in general..
    Good luck
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11327
      Ron yes the left wire loom bracket has a threaded boss for the wing nut.
      e.g.
      • Ron L.
        • July 31, 1998
        • 111
        Thank you so much - that is what I thought. On another issue - do you know of a video or written explanation on the installation of the headlight assemblies for the 64 - I suppose any C2 might be the same.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11327
          Ron,
          In the Sticky Threads at the top of the TDB is a list of Restoration Documents HERE.
          On the Main Page there is a pdf in the "Headlight" category. This one gives a good outline of disassembly and installation.
          C2 Headlight Seminar 2011
          Rich
          PS Welcome to the TDB !!! I just noticed this was your first post. Glad to have you join in.
