L 72 427 timing cover seal - NCRS Discussion Boards
  • Doug M.
    • December 31, 1990
    • 68
    Wondering if anyone manufactures a double lip seal ?
    Using SKF 23300 now with an annoying slight drip.
    Thankyou in advance, and Happy New Year
    Doug
  • Mike T.
    • December 31, 1991
    • 568
    Re: L 72 427 timing cover seal
    Doug - I just finished assembling a Bigblock for my 65 L78 Roadster and pretty sure I used that number SKF front timing seal. Haven't fired it up yet so hoping there will be no leaks but let me ask a couple questions. Was the hub on your old balancer in good shape or did you have to use a sleeve? And, when you installed the new timing cover seal, did you add in a light smear of silicone to the opening of the cover?
    PS - Sent you a PM regarding your L72.
    Mike T. - Prescott AZ.
    • Mark L.
      • 556
      Doug, I had that problem. Usually it is related to wear on the harmonic balancer. Install a sleeve and I'd bet it gets resolved.
      • Doug M.
        • December 31, 1990
        • 68
          • January 31, 1988
          • 43195
          Originally posted by Doug McClure (18547)
          Mike and Mark,
          Gonna ‘ try the sleeve, thanks
          Doug
          Doug------
          The repair sleeve is of VERY thin material. With the repair sleeve it's CRITICALLY IMPORTANT that it be installed "straight-and-true". If it's not done PERFECTLY you'll have a leak worse than before. A special tool is available to assist this installation process but even with the tool if one is not exceedingly careful it won't end up well.
          • Doug M.
            • December 31, 1990
            • 68
            Joe,
            Thanks, appreciate the information
