1967 power brakes - NCRS Discussion Boards
1967 power brakes
  • Gary A.
    • May 31, 2001
    • 165
    1967 power brakes
    My 67 is a power brake car originally, but the booster was removed some time ago and I re-installed this weekend. I notice a couple things that I couldn't get a answer from on the archives. First, the pedal location is much shorter. The brake and clutch pedals pre booster were even, now brake is half distance to floor. I adjusted as far up as possible on the clevis, but still nowhere close. Second, the pedal throw isn't more than 3" when I depress the brake pedal. Engine off, no vacuum. Is this natural for a power brake car? Appreciate any comments or recommendations. Gary
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 1967 power brakes
    The brake pedal with power boost assist will sit lower than the clutch pedal...this is completely normal. Your first picture looks normal. My'67 for reference.
    Leif
    • Gary A.
      • May 31, 2001
      • 165
      Thanks Leif. I tried to right the photos, but..
      • Harry S.
        • July 31, 2002
        • 5346
        Did you change the mounting hole? This is from the 63 AIM.
        • Gary A.
          • May 31, 2001
          • 165
          Harry,I did. I used the lower hole for clevis from booster and upper for brake switch strike.
