Hi, I'm in the process of trying to remove the antenna from my 85 C4, I have the antenna removed from the bracket and the harness disconnected from the relay. I found a plastic clip holding the antenna harness which I removed and I disconnected the antenna wire from the mast, the antenna is now hanging from the harness. I believe the only thing holding the harness in place is the grommet although I can't pull the harness from the rear hatch or from the fender well. The grommet has the antenna harness and the antenna wire in it.
The grommet is difficult to get to, does anyone have a procedure for removing the grommet, also I have not removed the luggage shade yet, is this required? My antenna motor stuck halfway down with the motor running continuously, I'd like to repair this if possible if not can anyone suggest a quality replacement, the ones I've looked at seem to have a screw on for the antenna wire while my antenna wire has a fixed end on it which attaches to the mast with two small self tapping screws.
Any help would be greatly appreciated.
