Axle ratio question - NCRS Discussion Boards
Axle ratio question
  • Anthony C.
    • March 21, 2022
    • 207
    Axle ratio question
    Hi , my dealer invoice on my 75 says G95 highway axle ratio however cannot find it in my NCRS specifications book . Does anyone know the ratio
  • Ed H.
    • November 1, 1999
    • 626
    Re: Axle ratio question
    Anthony, is your car 4-spd or auto, auto is either 3:50 or 3:36, 4-spd could be 3:70 check the differential for numbers or date codes, they should be stamped somewhere on the unit, photos would be good.
    • Anthony C.
      • March 21, 2022
      • 207
      Hi 4 speed .. spec book does not list ratio 67B1C8E4-F3DA-4AB9-9948-DD7559DBDABC.jpeg
      • Dan A.
        • February 1, 2004
        • 212
        I believe your car is the L48/4 speed combination. The “highway axle ratio” should be a 3.08 based on my research. Is your axle code AW?
        • Anthony C.
          • March 21, 2022
          • 207
          no invoice says G95
          • David H.
            • June 30, 2001
            • 1544
            Originally posted by Anthony Cammaroto (69061)
            no invoice says G95
            Anthony
            Look at your car, not the paperwork.
            Dave
            Judging Chairman Mid-Way USA (Kansas) Chapter
            • Dan A.
              • February 1, 2004
              • 212
              That would be the RPO code, I think. The AW is what might be stamped on the rear end. However, I don’t see G95 listed as a 75 RPO code in my limited resources. I did see it listed as economy axle ratios on other years in the later 70’s.
              • Anthony C.
                • March 21, 2022
                • 207
                • Anthony C.
                  • March 21, 2022
                  • 207
                  ok trying to post dealer invoice
                  • Dan A.
                    • February 1, 2004
                    • 212
                    Have you tried the old shade tree method of counting the driveshaft rotations per one rotation of a drive wheel?
                    • Anthony C.
                      • March 21, 2022
                      • 207
                      I have not .. this is the dealer invoice 5A01A4A4-2182-4E43-ADB8-DC07F3914F2A.jpeg
                      • Anthony C.
                        • March 21, 2022
                        • 207
                        • Dan A.
                          • February 1, 2004
                          • 212
                          I’m sticking with 3.08.
                          • Ed S.
                            • August 6, 2014
                            • 1377
                            If your car is an automatic the G95 "highway" axle ratio should be 2.73:1. If you have a 4 speed a highway axle ratio was 3.08:1. Highway axle ratios were only available with the base engine. Highway ratios were not paired with the optional L82 engine.
                            Ed
                            • David H.
                              • June 30, 2001
                              • 1544
                              Anthony
                              What is source of your dealer invoice?
                              Is GM original source, or is this a reproduction copy?
                              Can't find "G95" in my Parts Book RPO Code list.
                              Dave
