Original vs. Repro C2 Oil Canister - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5333
    I came across a C2 Oil canister and can not tell if it's original or not. I searched the archives for almost an hour looking for measurement on both, no luck
    Anyway, anyone know the metal thickness of the original vs. a repro.
    Thank you
  • Bert L.
    • April 30, 1977
    • 427
    Re: Original vs. Repro C2 Oil Canister
    Somewhat of a coarse measurement for you Harry, but should be sufficient for your purpose. The original to the car can on my '60 has 3/32" (.09375)+ - thick walls. *I can't comment on the reproductions.
    • Bruce W.
      • June 30, 1997
      • 360
      I have both original and repo. I am not home so i can't measure it. But i recall the repo is probably half the thickness of the original. the repo tend to leak.
      • Harry S.
        • July 31, 2002
        • 5333
        Bruce, I agree. If I have an original I'll restore it. If I have a repro I'll recycle it. If you could measure yours that would be great. Thanks
        • Harry S.
          • July 31, 2002
          • 5333
          Just got a call, original thickness .1100 with paint. Repro .890.
          The one I have is .1070 with thin worn paint, looks like I have an original.
          Thanks All
          • Harry S.
            • July 31, 2002
            • 5333
            Thank you Frank Dreano for sending the oil canister. I decided to take another approach instead of a push washer. I used a pipe cutter, the one plumbers use to cut copper pipe. I used the measurement I gatherer and cut a ring into the canister bolt, not too deep. I then took my Dremel and made the cut wider. Took a new crush washer for fit then installed a 1/2 retainer ring. As soon as I find the bell, spring, metal washer and rubber washer I'll put it back together.
            • Bert L.
              • April 30, 1977
              • 427
              Nicely done Harry!....
              If decide to do mine, instead of using a Dremel I'll attempt
              forming the ring using a drill press. (poor mans lathe)
              Definitely would try first on an ordinary bolt though!
              Looking forward to photos of the completed project.
              Cheers
              • Harry S.
                • July 31, 2002
                • 5333
                I found this online, instructive to help rebuild your canister.
                Oil Canister Rebuild.pdf
                • Bert L.
                  • April 30, 1977
                  • 427
                  Nice find Harry, thank you....
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11345
                    [ATTACH]115266[/ATTACH]
                    Harry, Nice. Thanks for posting that. I've added it to our Sticky Database Update page.
                    Rich
