Aero Rivet Tool??? - NCRS Discussion Boards
Aero Rivet Tool???
  • James W.
    • December 1, 1990
    • 2681
    Aero Rivet Tool???
    I need to install a new ground clip on my '65 distributor shielding. Does anyone have an Aero Rivet Tool that they would be willing to rent so that I can do this? Not wanting to spend $90 for a one time use tool.
    James
  • Brad Hillhouse (37766)
    Re: Aero Rivet Tool???
    James -
    Just sent you a text with a pic of mine.
    Cant remember if it is the Aero or a different brand.
    Let me know if you want to use it.
    brad
    • Bill B.
      • August 1, 2016
      • 313
      Hi James & Brad,
      I have one that you can use for free. The Aero tool has "MMI" stamped on the middle "C" part of the clamp. Also has several die pieces for both ends of the clamp to accommodate different size rivets and head shapes. I'm in CT right now, and can mail it out.
      Bill Bertelli
      Northeast and Carolinas Chapters Member
      '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
      • James W.
        • December 1, 1990
        • 2681
        Brad,
        I will bring my ignition stop shield with me to the upcoming chapter tech session and install it there if that's okay with you. I have the new clip, rivets and backing washers.
        Thanks, and see you on the 14th!
        James
        Originally posted by Brad Hillhouse (37766)
        James -
        brad
        • James W.
          • December 1, 1990
          • 2681
          Bill,
          Thank you very much for the offer. I am going to use Brad's rivet tool to install the new ground clip at our upcoming chapter tech session. If for some reason it won't work, I will contact you.
          Best regards,
          James West
          Originally posted by Bill Bertelli (62632)
          Hi James & Brad,
            Sounds great James
            See you on the 14th
            Brad
