Question On The C2(66) Windshield Washer System - NCRS Discussion Boards
  • Larry E.
    • 1695
    Getting my 66 Base Engine Coupe ready for judging this Spring. Before I stored it(Omni Bag) for the
    Winter I tested the "Operations" of the car. One thing I came across was that the Windshield Washer
    System did not "pull" the fluid out of the reservoir. The wipers did work so I assume the control is OK.
    Bare in mind this is a 50 yr. old car and I do not know when washer system was used last.
    Question: Let's assume all the mechanics of the system are OK. Now>IS THERE SOME PROCEDURE
    FOR "PRIMING" THE SYSTEM TO START THE PROCESS WORKING INITIALLY??
    I seem to recall when we restored my other 66 (Convertible) we did something to get it started to pull
    the liquid for the 1st time; once done it worked all the time. Do not remember what we did as this was a long time ago. Comments Please>> and thanks>>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Harry S.
    • July 31, 2002
    • 5342
    Re: Question On The C2(66) Windshield Washer System
    Typically it's the below inside the unit close to the three hoses. It either is dry or cracked. Four things to try:
    1) blow water through the tube coming from the tank, if that does not work,
    2) remove the below and put a lubricant on it to help it seal & lubricate the three rubber check valves, if that does not work,
    3) replace the below, go back to step 1, if that does not work,
    4) replace the unit the plastic part that has the three check valves, check for cracks in the plastic.
    • Leif A.
      • August 31, 1997
      • 3650
      Harry is spot on with his response. Just remember that the washer fluid will evaporate pretty quickly and if you're not using the system frequently the hoses will dry out and you will have to "prime" them again.
      Leif
      • Larry E.
        • 1695
        Thanks to Harry and Leif for the advice. Question For Harry>
        Your advice was to use "Lubricant"; what kind would you suggest? eg.>White grease/Vaseline/Engine Oil/ OR ???
        Thanks Again>Larry
        Larry
        • Harry S.
          • July 31, 2002
          • 5342
          Thanks Again>Larry
          Never use anything that will harden (white grease). I've seen hand cream work. I use Danco Waterproof Grease on my water softener O-Rings (rubber) so I used a thin application on the below and a thin application on the check valves. On the check valves all you need is the side that makes the seal. Remember this is old check valve rubber and they are delicate, be gentle.
