Re: 1993 LT1 Intermittent Crank-No Start
With phone support from Ed Johnson (thanks Ed!) I’ve reached a diagnostic conclusion and want to run it by the experts here.
Beginning with the “Engine cranks but doesn’t run” A-3 flowchart in the FSM:
Is RPM indicated on Tech 1 during cranking?
I don’t have a Tech 1 but no RPM indicated on car’s tach. To be thorough, I ran through YES and NO branches and compared conclusions:
NO RPM Indicated
Voltage on terminal C of distributor connector while cranking? YES
Continuity between terminal D and ground? YES
This means faulty distributor or distributor connection
YES, RPM Indicated
Spark at spark plugs? NO
Use Chart C-4 (Ignition System Check)
Spark at coil secondary cable? NO
Voltage at Ignition Coil Module terminals A and D? YES
Voltage at Ignition Coil Module terminal B (4v AC) NO
while cranking?
Low resolution signal while cranking? NO
(Ed’s method to determine this w/o a Tech 1: Turn ignition on; fuel pump primes to 40 psi; bleed pressure while keeping ignition on; crank engine. Pump did not activate ==> no low resolution signal.)
(Dave Perry’s method: Same as above without bleeding fuel pressure. Same result.)
Voltage at distributor connector terminal C? YES
Is distributor connector terminal D grounded? YES
5v at distributor connector terminal A? YES
5v at distributor connector terminal B? YES
So same conclusion either way (with and without RPM signal). The harness connectors at the distributor and on the intake manifold look clean and dry and have continuity so my conclusion is the distributor is faulty.
Answering Dave’s earlier question: The spark plugs are dry (I checked two of them).
Feedback welcome.
Thanks again!
NO RPM Indicated
YES, RPM Indicated
while cranking?
Feedback welcome.
Thanks again!
