I recently removed the paint from the underbody fiberglass. I started by removing the exhaust, spare tire holder, drive shaft and half shafts in order to expose the tunnel fiberglass. After becoming frustrated with the usual thinning and stripping products I conducted some online research and found a company out of New Zealand that produced a product specifically designed to strip paint from fiberglass (https://coopersstripclub.com/). Skeptical at first, but after using it, it literally walks the paint off the fiberglass. I used shop clothes and various grades of steel wool. Finished with a healthy bath of diluted Simple Green to remove any residue. It's a time consuming job full of elbow grease but you should be able to complete in ~20 hours. Here's the before and after for anyone looking to pick up points by restoring them to the original condition.
C2 underbody fiberglass paint removal
Re: C2 underbody fiberglass paint removal
My neck and back got sore just looking at those pictures. But, seriously, a terrific job...looks fantastic!Leif
Top Flight 2017 Lone Star Regional- Top
Agreed, I'll likely have permanent nerve damage for which my wife has no sympathy :-) Next to replacing the windshield washer motor, this job was a treat. Working on stripping the paint off the drive shafts and installing period-correct U-Joints.- Top
Very nice!
Never heard of this product, so thanks for sharing.
I did mine with Citristrip. It is indeed a lot of work, but well worth it.
My body was off, which made it a bit easierRegards,
Brian McIntyre- Top
I went online in an attempt to determine the active ingredients in the Copper strip. couldn't find any list of its ingredients. since methylene chloride was outlawed in the USA, I have yet to use any strippers like the old Captain Lee stripers that did contain methylene chloride. whats coppers ingredients? btw, online cost per gal about 900 bucks . mike mccagh- Top
Bead blasting might work.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Great job Thomas. I went through a similar dirty process after replacing the battery box in my '70. The gel coat (or whatever that semi-opaque grey finish is) on the fiberglass was in good condition so I just removed the grime, scuffed the surface then applied a light coat of matte clear. Looks great and preserves the original color.
I masked and worked around the suspension and driveline. Similar process for the spare tire tub.
(Thumbing this while waiting for the Christmas tamales and guests. Happy holidays!)Mark Edmondson
Dallas, Texas
Texas Chapter
Has anybody tried the dry ice method or stripping underside.? I have seen it used by the Porsche people and it comes out like the day it came off the assembly line, Yes. Porsche is metal and covered by cosmoline that preserves pretty well from the factory
cost is around $400 I hear and THEY do all the dirty work. Personally, I have used enough acetone to remove "rattle can restorations", my hands / skin are not a pretty site. Merry Christmas all- Top
Dave
My body was done in Imron. On the flat surfaces I used a razor blade. Pretty well just peeled off. On the curved surfaces, like the gill area, the Citristrip left overnight came off with a course 3M pad and lacquer thinner. Several treatments were required. Those were among the most difficult areas to do.Regards,
Brian McIntyre- Top
Dave
My body was done in Imron. On the flat surfaces I used a razor blade. Pretty well just peeled off. On the curved surfaces, like the gill area, the Citristrip left overnight came off with a course 3M pad and lacquer thinner. Several treatments were required. Those were among the most difficult areas to do.- Top
You can use a razor blade going from top to bottom rather than side to side to get most of the surface if that makes any sense. As you point out, there are a lot of places where the stripper will be the only way.
Good luckRegards,
Brian McIntyre- Top
