62 or 63 4-speed shifter differences? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Not sure if I have a 62 or 63 shifter assy. what are the visual differences? Using with a T10
  • Mark M.
    • October 21, 2008
    • 340
    Re: 62 or 63 4-speed shifter differences?
    If you post a left side and a rear view picture of the shifter with the linkage levers straight down, I may be able to give a part # and application. I have a few vintage Hurst catalogs.
    • Mike E.
      • February 28, 1975
      • 5141
      I believe the shifter body itself is the same. The reverse rods are different between 62 and 63. And a 62 has a white knob and a 63 black. 🙂
      • William B.
        • April 30, 1975
        • 942
        I have found the reverse lever on the shifter body is different, so also the rod would be different, and knob went from white to black.
