Anyone seen this spark plug wire terminal ends corrosion - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I'm helping a friend with his 67 427/400 car. We pulled the plug wires out of the distributor cap to get them out of the way and one broke loose and two others had significant corrosion of the terminal ends (pictures attached). I also included a picture of two of the cap posts where there is either a burned area or something else causing some part of the post to be chipped or something.
    Anyone know what caused this? My first thought was moisture, but this car is kept in a garage, not driven in the rain, and not washed under the hood with any water.
    by the way, these plug wires are less than two years old, and all the other terminal ends where clean with no signs of the corrosion.
    Any help is much appreciated.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Mark E.
    • April 1, 1993
    • 4600
    Re: Anyone seen this spark plug wire terminal ends corrosion
    Corrosion is caused by moisture. The two towers affected also look burned.
    One possibility is these two cables were not fully seated, allowing moisture to enter and causing arcing.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Donald H.
      • November 2, 2009
      • 2586
      What is strange is that all the wires seemed to be seated and while the two cap towers show what looks to be burning the rubber boots do not have any melting or such.
      Don
      Don Harris
      • Michael M.
        • February 1, 1993
        • 604
        Use silicone dielectric grease when you install your plug wires. Put some on the spark plug end and distributor cap end.
        • Owen L.
          • September 30, 1991
          • 882
          Could this be galvanic corrosion between the two metals? (Am not much of a metallurgist though I do watch YT videos!)
          • Donald H.
            • November 2, 2009
            • 2586
            I was also wondering about galvanic corrosion, but it only happened with three of the wires. It is one of the better reproduction caps.
            Don
            Don Harris
            • Thomas S.
              • February 7, 2016
              • 618
              67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
              • Mark E.
                • April 1, 1993
                • 4600
                Originally posted by Thomas Sutcliffe (62028)
                ...it’s pretty easy not to fully seat cap wires as well.
                True that. Especially 90 degree tower boots.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
