C2 oil canister bolt - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5330
    If anyone has their C2 Oil canister out of the car, can you measure the outside diameter of the long bolt in two places. The thinner top part and the wider section at the bottom where the bell and spring fit.
    Thanks and Merry Christmas.
  • Donald O.
    • May 31, 1990
    • 1593
    Re: C2 oil canister bolt
    I'll go look and report back tomorrow.
    • Donald O.
      • May 31, 1990
      • 1593
      This good enough? I can get mor photos of measurements if needed.
      Don
      i have no idea why this shows turned 90*
      • Harry S.
        • July 31, 2002
        • 5330
        Don, that's perfect.
        Thank you and Merry Christmas.
        • Ralph E.
          • February 1, 2002
          • 905
          That Don always comes through
          • Harry S.
            • July 31, 2002
            • 5330
            Don, if the bolt is still available, what is the measurement from the top to the top of the nubs? I'll cut a pipe that length to install a press on clip.
            • David Z.
              • April 1, 2002
              • 182
              This thread above may be relevant.
              https://www.forums.ncrs.org/showthre...ter-Repair-Kit
              Dave Z
              Dave Zuberer
              • Donald O.
                • May 31, 1990
                • 1593
                Will Do Harry. But I don't think the accuracy will be to the 3rd decimal.
                Don
                • Donald O.
                  • May 31, 1990
                  • 1593
                  Ralphie!!!!!
                  Where have you been hiding?
                  • Ralph E.
                    • February 1, 2002
                    • 905
                    Originally posted by Donald Olson (17357)
                    Ralphie!!!!!
                    I'm here all the time.
                    You just never noticed.
                    Merry Christmas my friend.
                    • Donald O.
                      • May 31, 1990
                      • 1593
                      • Harry S.
                        • July 31, 2002
                        • 5330
                        Don, Merry Christmas
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11334
                          Don I fixed your photos. Thanks for helping Harry..... Rich
                          PS Maybe you had autorotate ON. My Android does that even if it's OFF. This is how I fix them. Here.
                          • David Z.
                            • April 1, 2002
                            • 182
                            Here's a jazzed up version of Don's diagram. The attached PDF has an operable link to the thread. Not quite certain about the number for the NUB DIA.
                            Dave Z
                            Dave Zuberer
                            • Donald O.
                              • May 31, 1990
                              • 1593
                              sent you a PM mi amigo
