Half Shaft Clocking - NCRS Discussion Boards
Half Shaft Clocking
  • Ed D.
    • December 1, 1990
    • 329
    Half Shaft Clocking
    I just received my rebuilt trailing arms, which have no reference to original half shaft clocking. I noticed after attaching the half shafts that I can now turn the wheels, with the wheel off the ground. Before the wheels would bind on the half shafts. Is there a proper orientation that should followed for installing the half shafts to the trailing arms?
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
  • David H.
    • June 30, 2001
    • 1549
    Re: Half Shaft Clocking
    Originally posted by Ed DiNapoli (18386)
    ... I noticed after attaching the half shafts that I can now turn the wheels, with the wheel off the ground. Before the wheels would bind on the half shafts.
    Ed
    Did you change your shocks as well?
    Dave
    Judging Chairman Mid-Way USA (Kansas) Chapter
    • Ed D.
      • December 1, 1990
      • 329
      No, still the original shocks
      Ed
      Ed DiNapoli
      • Harry S.
        • July 31, 2002
        • 5336
        Ed, this is what we did on my 63. I'm sure others will comment.
        • Ed D.
          • December 1, 1990
          • 329
          Thanks Harry, did you follow any particular relationship on the universals orientation from left to right side. The assembly manual does not indicate any mention of how they should be installed.
          Ed
          Ed DiNapoli
          • Harry S.
            • July 31, 2002
            • 5336
            Ed
            No, but I have seen them 180 degrees out.
            • Joel A.
              • September 30, 1997
              • 214
              The shafts will turn independently on turns anyway, so it doesn't really matter if they are lined up("clocked") on assembly. Even lined up, they will no longer be lined up after you make your first turn, so...put them any way ya want.
              Joel Adams
              1974 Coupe
              1985 Coupe
              "I know the voices aren't real...but sometimes they have some really kewl ideas...."
              • Larry M.
                • January 1, 1992
                • 2701
                Agree............
                Larry
                • Ed D.
                  • December 1, 1990
                  • 329
                  Thanks guys, I should have put some more thought into this and figured it out myself.
                  Ed
                  Ed DiNapoli
                    • 15706
                    You didn't say what model year you have, but U-joint grounding can be a problem on '63 models due to the thick section of the cast iron outboard yokes. Rebound is limited by shock travel and some replacement shocks may be too long. The two later forged designs have thinner sections and more grounding clearance.
                    It's not clear to me from your post, but I interpreted what you said that U-joint grounding was an issue before you removed the halfshafts, but not after reinstalling them. If so I can't explain it.A
                    s others have said halfshaft clocking is not an issue since it won't last past the first sharp turn.
                    Questions should always be accompanied by the model year because there were many changes over the model years many of which are not visually obvious.
