Re: Winterize or Not?
Sitting in a sealed polymer container brake fluid cannot absorb moisture, and neither brake fluid nor antifreeze cause plastic to corrode.
Over time the brake system absorbs moisture that will eventually cause corrosion of the brake system metal components that are in contact with the brake fluid.
Cooling systems have dissimilar materials, like iron, aluminum, and brass or copper. When joined by an electrolyte you have a galvanic cell which is essentially a battery, and one or more of the metals will be sacrificed, aluminum usually being the first. Observe that your radiator is mounted with rubber isolators. The primary reason is to electrically isolate the radiator, so it's like a disconnected battery. Measure continuity between your radiator and ground. If it's not infinity, your radiator is not electrically isolated, which will substantially increase the rate of corrosion.
That's why brake fluid and antifreeze should be changed on a time rather than mileage basis. Both chemicals contain corrosion inhibitors, but they are consumed in the process of protecting the brake and cooling system materials and this process is 24/7, 365/6 days a year whether the car is on the road or parked, including storage. The clock runs on brake fluid and antifreeze in storage, but not on fresh engine oil.
For further information Web search galvanic cell and electromotive force (EMF) to see the hierarchy of elements and which are sacrificial when in contact with other elements, usually metal.
