Lectric Limited date coded plug wires - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    Are the LL date coded plug wires better constructed then in the past? Very fragile and prone to break causing an open wire. Just purchased a set for my 65 327/3654 coupe that will be NCRS judged.
    DaveK.
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Lectric Limited date coded plug wires
    Dave, tried two sets of LL wires, never ran right and finally one quit on me. Got a set of Summit Racing spiral wound wires, cut to size and used a good crimping tool to install dist. end contacts, best car ever ran, the wires are black and you can take off the markings etc. Make an ink stamp and you're done.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Harry S.
      • July 31, 2002
      • 5349
      Wire has always been a tough call. Look for a reel/spool of high quality wire and build your own. It might be more expensive with a stamp for the date code but you will be better in the long run. I found an original 100 ft spool of 4Q62 wire a few years back. Built 4 sets and the car runs great.
      Go with a solid copper core for best results.
        • 15643
        Each of the wires were sent to St Louis by Packard Electric assembled to length for each position and date coded. All the original wire sets I have seen have several date codes. A wire set all with the same date code is highly suspicious. I know it will be a PITA, but get several date code stamps and offer them to others when you are done.
        • Harry S.
          • July 31, 2002
          • 5349
          Terry, as I recall, LL only makes wires from the First and Third quarter of the year. That's to fit our (NCRS) 6 month rule.
          • Daniel S.
            • February 1, 2000
            • 165
            I've had a set of LL wires on my car for years without issues.
              • 15643
              Correct Harry. That is another reason to "make your own."
              • Jaime G.
                • April 1, 1988
                • 480
                I have had 7 cars with LL wires with no issues. I currently own 4 of those and the oldest wires are 19 years old.
