&F40 / &F41 Rear Spring ID - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 402
    Is there a "known" way to identify if a F40/F41 rear spring?
    I have a F40/F41 heavy duty spring and I'm trying to determine if it could be an original, service or aftermarket spring.
    The 1965 6th Edition Technical Information & Judging Manual doesn't provide much to help identify it (stampings, part number, date code, manufacture letters/numbers, etc).
    Can anyone help?
    Here are a few jpegs:
    Ray K (#43777)65 Vette - F40 Rear Spring_1 - 06Sep22.jpg65 Vette - F40 Rear Spring_2 - 06Sep22.jpg65 Vette - F40 Rear Spring_3 - 06Sep22.jpg65 Vette - F40 Rear Spring_4 - 06Sep22.jpg65 Vette - F40 Rear Spring_5 - 06Sep22.jpg
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11317
    Re: &F40 / &F41 Rear Spring ID
    Ray, For reference, here is a F40 spring on a '65 fuelie. Best of my knowledge original. Appears identical to yours.
    The only caveat is that I believe service replacements used that flat extra leaf on top. Not sure if 65 used that or not.
    Last edited by Richard M.; December 2, 2022, 07:15 AM. Reason: Ray, not Tim. Typo hiccup
    • Gary B.
      • January 31, 1997
      • 6992
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11317
        Good eye Gary, I didn't notice that in Ray's photos.
        Here are some from a '67 F41 7-leaf I restored. I had to replace the main leaf as it had a bad spot. Eaton's replacement was very good.
        Eaton left, Orig right
        • Gary B.
          • January 31, 1997
          • 6992
          Richard,
          In your photos, I see the expected ~1/8” reduced width for the last 2” or so at the end, and the classic ski jump end with the relatively sharp tip. I don’t see that 1/8” reduced width section on Ray’s spring. But I haven’t closed examined many GM HD springs to know if they all have those features. But the non-45 cut is concerning.
          Gary
          • Danny P.
            • June 30, 2002
            • 338
            Can anyone help?
            Ray K (#43777)[ATTACH=CONFIG]114601[/ATTACH][ATTACH=CONFIG]114602[/ATTACH][ATTACH=CONFIG]114603[/ATTACH][ATTACH=CONFIG]114604[/ATTACH][ATTACH=CONFIG]114605[/ATTACH]
            Ray , there should only be 7 leafs total and no liner between on 7 th and 6th spring and no top spacer , this a photo of my F41
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11317
              Originally posted by Gary Beaupre (28818)
              Richard,
              Gary
              Gary, yes that 65 spring I showed is in fact likely a repro. Its a 37k mile car, but was drag raced most of its life, then restored by my friend. He bought it in the mid 80s.
              After I posted the original 67 spring the features you mention are more obvious.
              Last edited by Richard M.; November 27, 2022, 12:37 PM. Reason: Moved edit to new post
              • Gary B.
                • January 31, 1997
                • 6992
                This table is from a Restorer article that Joe Lucia and I wrote about 10 (?) years ago. As one can see, for some years the HD spring had a flat top plate. A 1975 HD spring could easily be converted to a 63-74 HD spring by removing the top plate.
                Gary
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11317
                  PS... just remembered this thread from a while ago regarding the top plates.
                  • Gary B.
                    • January 31, 1997
                    • 6992
                    Gary
                    • Ray K.
                      • April 30, 2005
                      • 402
                      All,
                      Thanks for the very informative on my &F40/F41 rear spring.
                      Now the question becomes: what should I do with it?
                      Ray K
                      • James W.
                        • November 30, 1990
                        • 2644
                        It looks like all the other 6 spring leaves and top plate are correct. I'd buy a replacement bottom (main) leaf spring from Eaton Spring that has the correct 45 degress mitered end cuts. I would also buy a pair of the closer to original (shallower) replacement spring cushion cups from Gary Beaupre.
                        James
                        All,
                        Ray K
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11317
                          Gary, Nice document. Thanks for posting. I'll put that in the DoRD Sticky when I get a chance.
                          Ray, yours has a different profile on the ends of the angle cuts on the main leaf, so likely a reproduction. The rear spring gets 5 points for Originality, 5 for Condition. 10 Total. At worst case scenario, you'd loose 5 points for NTP. If mine, I'd restore it and use it.
                          So.... I went back and looked at the judging sheets on that '65 fuelie coupe that had that 7 leaf rear spring I pictured earlier.
                          It appears that at both the 2010 Florida Regional and the 2010 Charlotte Nationals, the spring did not receive a deduct for originality, other than a 1 point hit for not having the shallow cushion cups. So now I'm confused if it was just an oversight(twice!), or in fact it's a original GM spring. Unsure. My gut tells me it's not original because of the top spacer plate and the non-narrowed leaf ends. But I've not seen any other original '65 F40 springs.
                          • Gary B.
                            • January 31, 1997
                            • 6992
                            • Joseph W.
                              • February 19, 2022
                              • 368
                              C3 General - 79 gymkhana rear spring questions - Just picked up low mileage removed long ago 79 rear gymkhana spring. It is the last piece of my conversion to gymkhana option. my 9 leaf os 2 1/2 inch wide, the gymkhana looks like a 6 leaf with a spacer? Interesting.. that small top part is for sure not a spring it is...
