Does one piece oil pan gasket need sealer? - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2003
    I am using a Mahle black one piece oil pan gasket on a 1970 350. The package is silent about the use of sealer. Is there a consensus about using these things dry or with sealer?
  • Leif A.
    • August 31, 1997
    • 3644
    Re: Does one piece oil pan gasket need sealer?
    Patrick,
    I like to smooth a thin layer of Permatex Black on both sides of the gasket. Double insurance against any leaks. And, of course, be sure the mating surface of the oil pan is nice and flat. I hate oil leaks.
    Leif
    • Owen L.
      • September 30, 1991
      • 882
      I used dabs of sealer in the "corners" where the timing cover and rear mains meet the block.
      • Patrick B.
        • August 31, 1985
        • 2003
        • G B.
          • December 1, 1974
          • 1407
          Originally posted by Leif Anderson (29632)
          Patrick,
          I agree.
          They might seal okay (for a while) without silicone if you're installing an NOS pan on a never-fired engine block, but I've never had that privilege.
          • Patrick B.
            • August 31, 1985
            • 2003
            Good point about using the old original imperfect oil pan.
            They might seal okay (for a while) without silicone if you're installing an NOS pan on a never-fired engine block, but I've never had that privilege.[/QUOTE]
