A few months ago I had the opportunity to get a close look at this Delco 1115006 "Contact Controlled" transistorized add on system designed for points distributors. Fellow Member Mike E surprised me when it came in the mail, after he first sent me a email that "something was coming for you to tinker around with". Thanks Mike!
It was a GM over the counter item for Passenger cars/trucks, designed to work to extend points life and yield better spark. I suppose this could have been used for Corvette as well.
Here is what it looked like boxed up(web file photo). List price was around $88 in the 60's. Somewhat pricey back then.
Note that the AMP case is identical to the Corvette TI 1115005 module, designed to be used with the specialized TI pulse driven distributors using the magnetic pickup methodology.
Here are some closeups of the unit. Part# stamp and unique label.
Inside case after removing the back cover. It appears to use the same circuit board as the 1115005 TI systems, with less devices populated. Likely cost savings.
Circuit board removed. Positions for 2 transistors, but only one used.
Output transistor. Bendix also supplied electronics to Delco. Part # 1960632. Date code 4D1 = April 4, 1971. The 1960632 was replaceable and listed for around $30 back then. Note the ground plane/heat sink plate is the same used for the 1115005 TI system too.
After I was done investigating I hesitantly(
) sent it back to Mike.
