Does anyone recall what the length of the INDAK heater fan switch / cable is on a AC car versus a non AC car? Also Vinyl covered or not?
Heater Fan Blower Switch / Cable C2
Re: Heater Fan Blower Switch / Cable C2
Jimmy,
Are you referring to the outer black sheathing as the "vinyl" covering? If so then yes, it has the outer black cover. At least the one on my original '65 coupe woth A/C does. Can't help you with the length, as I did not measure it when I had it removed to fix the fan switch last spring.
James
Both Air Conditioned and non-Air cable lengths can be found with the reproduction versions listed on Corvette Central's website. (You might have to Click on "SPECIFICATIONS", for each version.
Their measurements don't start at the knob, because they list 28 inches for the non-AC version.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
