'70 tail light bulbs what is correct ? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    Got new tail light bulbs from Paragon, all 4 are 2 post - which seems correct for the outer taillights,
    but the wire coming to the two inner / center tail light assemblies is a single wire- shouldn't that inner assy bulb be a single
    post bulb ???.
    I am not sure post is the correct word, but set up to connect to 2 wires out side taillamp assy, inner/center tail light assy just one wire
    Clearly, electricity is not my strong point. Anybody have the correct bulb number handy ? Thanks
    • 43247
    Re: '70 tail light bulbs what is correct ?
    post bulb ???.
    Bob------
    The inner rear lamp is an 1156 which has a single electrical contact. The outer rear lamp is an 1157 which has two electrical contacts.
    By the way, the front turn signal lamps are also 1157 but 1157NA. The "NA" suffix denotes and amber glass color.
    • Bob B.
      • January 31, 2007
      • 524
      Is the amber still available?
        • 43247
        Bob------
        Yes.
        • Bob B.
          • January 31, 2007
          • 524
          THANK YOU, off to the auto parts store
          • Justin S.
            • July 3, 2013
            • 305
            Joe,
            Did the entire production run of 1970 utilize the amber bulb and clear lense?
            • Leif A.
              • August 31, 1997
              • 3645
              Originally posted by Justin Sibbring (58615)
              Joe,
              Did the entire production run of 1970 utilize the amber bulb and clear lens?
              Justin,
              1970-1971 used the amber bulb with clear lens. 1972 went with the amber lens.
              Leif
                • 43247
                Joe,
                Justin-----
                Yes, as Leif described.
                • Mark E.
                  • April 1, 1993
                  • 4600
                  Given the marginal taillamps in these cars (only a single bulb for each corner), consider the 2357 bulb, a plug in replacement for the 1157 with a 25% brighter brake/signal filament.
                  See https://automotivemileposts.com/tail...omparison.html
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
