Replacing 65 SB spark plug wires - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    I have done this before but forgot the tricks. Fortunately, I have a lift to raise the car. The right side looks like a nightmare with the alternator, battery, and heater hoses. I plan to remove the alternator and am considering draining the radiator and removing the heater hoses to get clearance. Any comments?
    Dave K.
  • Gary J.
    • April 1, 1980
    • 1246
    Re: Replacing 65 SB spark plug wires
    A quarter works pretty as far as removing the thumb screws. You will have to remove the lower shielding where the exhaust manifolds are. One end of the shielding is mounted to motor mounts bolts on the block. The other end that attaches to the block is slotted.
    • Dave K.
      • November 1, 1999
      • 952
      Shields are off
