1968 427 L-71 correct oil pan - NCRS Discussion Boards
  • Rocco S.
    • December 20, 2013
    • 176
    Re: 1968 427 L-71 correct oil pan
    Joe,
    Thanks for the info. It was hard to find any info on this "curved" tray other than it was factory installed on L-88. I recently acquired this at an estate sale and have no use for it so if anyone is interested....
    Rocco
    ROCCO SCOTELLARO
    1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
    • Scott R.
      Infrequent User
      • October 2, 2021
      • 28
      Hi Joe, Only my phonr number is Long Beach, I lived/worked in Ca. for 34 years, now in glorious Florida ! Scott
      • Scott R.
        Infrequent User
        • October 2, 2021
        • 28
        Question, Is it possible to remove timing gear cover without lowering the oil pan ? the extra 8" timing cover I have looks like it can be removed using care not to damage anything ? Scott
        • Mike T.
          • December 31, 1991
          • 568
          Scott - Yes, the timing cover can be removed without lowering the oil pan. My 65 L78 Roadster had a 454 in it when I bought it.
          Correction, a 454 with a 'Flat Cam'. I pulled the timing cover and then the cam (after hoisting the engine up a couple inches to clear the core support X-brace) and after installing a new cam, and with lots of scraping and cleaning, reinstalled the timing cover and no leaks.
          That did include a lot of careful scraping and cleaning to try to minimize
          any silicone or gasket debris from dropping down into the pan.
          Mike T. - Prescott AZ.
          • Scott R.
            Infrequent User
            • October 2, 2021
            • 28
            hI Mike, thanks for the info, I have the motor standing on flywheel end, after I lossened the pan bolts it came out easily, I also took the pan off to see if it has all the parts it should and it looked great. Scott
