Chassis VIN Stamp - NCRS Discussion Boards
Chassis VIN Stamp
  • Paul A.
    • April 21, 2021
    • 227
    Chassis VIN Stamp
    Hello All, Is there a full or partial vin stamped into the chassis on a c2? Is it accessible or readable and where is it located? Regards.
  • Harry S.
    • July 31, 2002
    • 5296
    Re: Chassis VIN Stamp
    https://www.forums.ncrs.org/showthre...ht=frame+stamp
    A partial VIN...
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      A quote from John Hinckley....
      https://www.forums.ncrs.org/showthre...052#post731052
      On the 66-67, the 2nd stamp can be seen in this area.
      • Mark F.
        • July 31, 1998
        • 1524
        Paul,
        As Harry shows, mine was just forward of the left (driver's) side rear kickup.
        I was able to read mine ('67 no side-pipes with the body on) using a dental mirror and a flashlight. Not easy, but it's doable.
        Also remember if you do it that way, you're reading the numbers in reverse.
        thx,
        Mark
        • James W.
          • December 1, 1990
          • 2655
          Here are pictures I took of my frame VIN stamp on my late production '65 coupe. It is located in the area of Rich's picture in his response. I was able to get pictures of it with the body on the frame using an inspection mirror and my cell phone camera. Notice the mistake made by GM when they did not change the last number from a 4 to a 5 and stamped over it. The VIN matches the VIN tag under the dash, on the engine stamp pad and on the transmission case 22095.
          You will most likely have to do some cleaning and sanding to see the numbers. I used 320 grit sandpaper to carefully sand in the area until i started to see the numbers using the inspection mirror and a good magnetic flashlight. It helps to have someone help you by either holding the mirror while you take the pictures or vise versa. My car was bought new in Dallas Texas and spent the majority of its time in the southwest until coming to Iowa in 1974 and then never seeing winter weather so the frame didn't need much sanding. There is a function on your cell phone to mirror image the pictures you take because they will be backwards when you take the picures of the numbers in the inspection mirror.
          James
          • Harry S.
            • July 31, 2002
            • 5296
            Originally posted by Danny Pantuso (63794)
            If am not mistaken , 63-64 never came with frame Vin. # Stamping I believe it started in 65 , Danny
            Danny, the picture I posted in post # 2 is from my 63.
            • Michael J.
              • January 27, 2009
              • 7122
              Yes, all my '64s and my '63 has it.
              • Danny P.
                • June 30, 2002
                • 341
                Maybe i,am thinking of the Over the Arch Stamp Vin.# that started in 65 to 67
                • Arland D.
                  Moderator
                  • July 31, 1980
                  • 422
                  63 and 64 frames had both the VIN stamps. What did start for 65 - 67 was the addition of a year stamp 5,6, or 7 as a prefix for the VIN where as the 63 and 64 frames began with the S character and had no year designation prefix.
                  • Paul A.
                    • April 21, 2021
                    • 227
                    Great info and links! I thought the vin was located by the body mount. I was not aware there was another located forward for my 66. Try to tackle this weekend. Probably easier to remove tires and do the search. Hopefully I can report back with some findings. My car does have side exhaust so it will probably be that more difficult.
                    • Bob R.
                      • June 30, 2002
                      • 1595
                      On my 63 I was able to read the stamp at the kick up with the body off the frame but I could not read it with the body on just too much dirt and surface rust. I could not locate the stamp at the drivers door opening even with the frame off just too much rust there.
                      • Danny P.
                        • June 30, 2002
                        • 341
                        great info , thanks for clearing that up
