Recommendations for c3 1973 radio repair? - NCRS Discussion Boards
  • Timothy S.
    Infrequent User
    • January 3, 2021
    • 1
    I just recently acquired a 1973 454 big block and in the process of getting it judged, but the radio is not working. All the rights turn on in the radio but has no sound at all. I'm having trouble finding someone to repair the radio to keep it in it's original form. Any recommendations would be appreciated! I'm in the York county area of Pennsylvania if someone is local to here would be even better, since I would rather deliver the radio myself than have to send out.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17661
    Re: Recommendations for c3 1973 radio repair?
    Timothy,
    Don't know of any NCRS member that's still doing radio repair.
    Doctor Don's does excellent work and restored my 1992 ZR-1 radio and amplifiers. Fast service.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John S.
      • June 15, 2015
      • 505
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
      • Mark E.
        • April 1, 1993
        • 4540
        The dial light might be on a separate circuit than the radio (I'm not sure without checking though). So make sure the radio itself is getting power and its fuse is good.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Michael G.
          • March 2, 2008
          • 485
          Check that the speakers are not the problem. They were the problem in my case.
            • 11643
            My thoughts as well.
            If the radio light goes on, but no noise, check your speakers first. They die far more often than radios.
            • David C.
              • June 30, 2006
              • 126
              I have the same issue in my 1973. What is the easiest way to check the speakers?
              • Owen L.
                • September 30, 1991
                • 868
                When you turn the radio on, you should get a "thump" and/or see the cone move. My '72's speakers were completely rusted in the cone magnets and wouldn't budge. I ended up buying a pair of 8-ohm dash speakers from S&M Electro-tech. Robert Pacini went through my radio and recommended S&M.
