69 427 Oil Line - NCRS Discussion Boards
69 427 Oil Line
  • Jack O.
    • July 31, 1996
    • 527
    69 427 Oil Line
    Referring to the attached picture:
    - Anyone know where I can buy just the compression fittings?
    - The line on the bottom is a repro while on the top is a line I took off one of my prior Corvettes. The judging manual says the line is steel and has a picture which is just a plain steel line, like on the top. The repro appears to be steel core but with a copper laminate or some such. Assume plain steel is correct? Assuming so has anyone ever tried removing the copper coating?
    Jack
    Jack Ottofaro
  • Leif A.
    • August 31, 1997
    • 3644
    Re: 69 427 Oil Line
    Copper coating is correct.
    Leif
    • Justin S.
      • July 3, 2013
      • 305
      Re: 69 427 Oil Line
      Jack,
      The fittings can be purchased at hardware or auto parts stores.
      • Jack O.
        • July 31, 1996
        • 527
        Re: 69 427 Oil Line
        Originally posted by Justin Sibbring (58615)
        Jack,
        Not at any stores around me to include - Lowes, HD, ACE, Oreily's, Advanced, AutoZone - at which point I gave up. These are not the standard "barrel" shaped compression fittings which I have no problem finding.
        Jack Ottofaro
        • Jack O.
          • July 31, 1996
          • 527
          Thanks (NM)
          Thanks for that
          Jack Ottofaro
            • 15616
            Re: 69 427 Oil Line
            Jack
            Try McMaster Carr. Their on-line catalog is the gold standard for on-line catalogs. If you have the measurements of the line I would bet they have the connectors and associated parts.
