Speedometer & Tachometer Inner Cable Replacement - NCRS Discussion Boards
  • Bill B.
    • August 1, 2016
    • 305
    Howdy everyone!
    A quick question on replacement inner core cables for Speedo & Tach.
    I see AC P/N 620LH (GM P/N 6479185) is available from as NOS from multiple sources on ebay.
    I am just curious what the "LH" means. All I can think of is "left hand", which is intended to drive the instruments in the opposite direction.
    Is the 620LH acceptable for use as a replacement in our mechanical drive units?
    Thanks!
    Bill Bertelli
    Northeast and Carolinas Chapters Member
    '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
    • 43273
    Re: Speedometer & Tachometer Inner Cable Replacement
    Originally posted by Bill Bertelli (62632)
    Howdy everyone!
    Thanks!
    Bill-------
    Well, I don't know what the "LH" suffix of the AC part number refers to but I don't think it has anything to do with cable rotation. In any event, the GM #6479185 is a SERVICE speedometer inner cable applicable to applications requiring an 81" to 172" inner cable. It might be usable for a tachometer drive application but it was never cataloged for such an application.
    However, I do not recommend its use for speedometer applications. The GM #6479185 is designed to be cut to the required length and a plastic tip then installed on the instrument end. This design has been proven to be very problematic. A better solution is the use of cable GM #88960343 which remains available from GM to this day. It's of the same length as the 6479185 and is cut to the required length. Then, a steel tip is installed using a small tool supplied with the kit.
    The best solution is to have a speedometer shop make you up a cable.
    • Joe R.
      • July 31, 1976
      • 4552
      The following shop has proven to be very reliable!
      Deluxe Speedometer Service
      John Rullo
      2330 S. Kalamath Street
      Unit A
      Denver, Colorado 80223
      1 303 629-6958
      1 888 907-6505
      • Bill B.
        • August 1, 2016
        • 305
        Thanks Joe & Joe !
        B
        Bill Bertelli
        • Pat H.
          • December 1, 1996
          • 421
          Would this cable work for a tach on a C 1?
            • 43273
            Pat------
            All I can tell you is that it was never cataloged by GM for that application. However, I do think it would work. But, the deficiency I described above would still apply.
            • Paul Y.
              • September 30, 1982
              • 570
              I agree, we are blessed to have this old establishment in our city. Paul
              John Rullo
              Unit A
              1 303 629-6958
              1 888 907-6505
              It's a good life!
              • Michael L.
                • December 15, 2006
                • 1413
                Why bother replacing the inner cable? I used re-pop cables I sourced from a vendor on my 69 resto and they work flawlessly with zero bounce in either the tack or speedo, and they came ready to install with zero issues. I removed the inner cable and applied a light coating of kable ease and then reinstalled the inner cable, prior to installing on the car. Unless you're focusing on originality for a very special car, I think I would just get new cables IMHO.
                Amazon.com: KABLE-Ease Cable and Chain Lubricant for All Control Cables - Stops and Prevents Cable Breakage : Automotive
                Mike
                • Pat H.
                  • December 1, 1996
                  • 421
                  It was just a thought. The cables on my 59 are original, which I found years ago. The tach is fine its just the speed that has some bounce at low speed when you start to accelerate but then it fine. I did use Cable ease prior to installing it
                    • 43273
                    The needle bounce problem is most likely not related to a tach cable but more likely related to an instrument problem
                    • Pat H.
                      • December 1, 1996
                      • 421
                      The spedo was rebuilt by Corvette Clocks by Roger about 15 years ago. Maybe it's time but its a PIA to remove the dash
