'67 coupe with AC- need recommendations for front coil springs OEM look - NCRS Discussion Boards
  • Garry B.
    • January 1, 1991
    • 660
    I have already looked at Eaton and they don't make a standard spring for my '67 coupe, so looking for recommendations for front coil springs that are as close to OEM as possible. Thanks.
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
  • Leif A.
    • August 31, 1997
    • 3641
    Re: '67 coupe with AC- need recommendations for front coil springs OEM look
    Garry,
    Look at the link below from Eaton. Your stock front spring with factory A/C are heavy duty.
    Select the Year, Make, Model, Body Style, and Engine Size of your ride below. Help Ordering Online If you cannot find your springs in the parts lookup below, call us during office hours at 1 (313) 963-3839. Alternatively, fill out this form completely to request a quote from our sales team.
    with factory AC Heavy Duty 1 $ 224.00/pr 20
    Leif
    • Garry B.
      • January 1, 1991
      • 660
      Originally posted by Leif Anderson (29632)
      Garry,
      Leif, I can always count on you for great advice and help. I know that the BB with AC takes a heavy duty spring, but didn't realize that my SB with AC would also. Thanks.
      Garry Barnes #18531
      • Domenic T.
        • January 29, 2010
        • 2452
        Gary,
        When I looked up the changes way back, one was the springs. The HD springs can cause cracks and A/C doesen't add that much weight. The comp is 37 lbs and the condencer and evap aren't that much weight. Well maybe the 3 lb charge of freon was it!! I went back to std pprings for a better ride.
        Dom
        • Garry B.
          • January 1, 1991
          • 660
          Dom, thanks for your input. I could not find the standard springs on the Eaton site. I believe the standard springs have 12 coils. Do you happen to know what the standard springs part number was from Eaton? Did you get yours from Eaton? I see Zip carries what appears to be an as OEM spring that might have come from LIC. Many of the guys bought them from LIC when they were in business.
          Garry Barnes #18531
