Help with 1964 Stingray heater box refurbishment. - NCRS Discussion Boards
  • John W.
    • December 15, 2015
    • 61
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Help with 1964 Stingray heater box refurbishment.
    I would sand the flat sides of the shafts down a bit.
    • Justin S.
      • July 3, 2013
      • 291
      John,
      I just rebuilt my heater box and agree with Russ. Sanding the D shaped shaft made it easier to install.
      • John W.
        • December 15, 2015
        • 61
        • John W.
          • December 15, 2015
          • 61
          • John W.
            • December 15, 2015
            • 61
            • Ron L.
              • July 31, 1998
              • 111
              John - that piece of restoration is ahead of me. Glad you posted the question and the sanding and WD-40 will help. So, do I gather that these pieces can be replaced without separating the heater box? And, where did you purchase the re-build pieces from? I have been purchasing all of my restoration parts from Paragon. They have a great catalog with pictures, and their sales staff are really helpful with questions. Thanks, Ron
              • John W.
                • December 15, 2015
                • 61
                • Ron L.
                  • July 31, 1998
                  • 111
                  Sounds like good advice. That project is next on my list. What did you use to clean the box?
                  • Harry S.
                    • July 31, 2002
                    • 5305
                    From the archives, there are many more there...
                    https://www.forums.ncrs.org/showthre...ghlight=heater
                    • Mike T.
                      • January 1, 1992
                      • 568
                      Ron, I know your question was posed to John, who started this thread, but just wanted to mention I also get a lot of parts from Paragon, including the heater box rebuild kit. I didn't spot this thread when it first came out but am curious how John, or anyone who's fully disassembled a midyear heater box or just driven out those shafts ever got the flappers out without bending or busting up the various parts. Thanks.
                      Mike T. - Prescott AZ.
                      • Ron L.
                        • July 31, 1998
                        • 111
                        See about three earlier replies. He ground out the rivets and split the box - then used pop rivets when at reassembly. That is what I will do since I am not doing a points restoration - just want to get it on the road to drive.
                        • Ron L.
                          • July 31, 1998
                          • 111
                          John - could you do me a favor and measure location of you side emblems on the 64 convertible? I am interested in the distance of 1) fender side of door jam to edge of nearest tip of the V (right is suppose to be different than left), 2) same tip to finder line at the top, 3) bottom of V to bottom style line. It would be most appreciated.
                          • John W.
                            • December 15, 2015
                            • 61
                            I also have the Aero Rivet Tool II (advertised in Driveline), which I purchased specifically for installing the vent window channels on my convertible. I was able to install the vast majority of the rivets with that tool, but a couple rivets were just impossible to set deep in the recesses of the box, so I used pop rivets. A quality pop rivet gun makes a big difference. (They do make them.)
                            Regards, John
                            • Michael G.
                              • November 12, 2008
                              • 2157
                              Anyone know if all C2 heater boxes are identical?
                              Mike
