1963 stamp pad with short leg R - NCRS Discussion Boards
  • Danny P.
    • June 30, 2002
    • 344
    I,am trying to figure out at what point of the 1963 Vin.# did they start using the short leg R like the (attachment photo) DannyCorvette-Stamp-Pad.jpg
  • Arland D.
    Moderator
    • July 31, 1980
    • 426
    Re: 1963 stamp pad with short leg R
    Can't say if there is an established start and/or end date for the short legged R but this example is from a July block like the one in your photo.
    • Danny P.
      • June 30, 2002
      • 344
      thanks Arland, i went back to F05 and F04 they all had long legged R
      • Arland D.
        Moderator
        • July 31, 1980
        • 426
        Danny,
        Do you have a build date for the car with the '0715' stamp? Considering that six of the seven characters are the same and they were stamped ten days apart, they look like a good match.
        • Danny P.
          • June 30, 2002
          • 344
          Arland, with my search looks like late May and on they started using shorter legged R anything under May and earlier they all used the longer legged R
          • Thomas S.
            • February 7, 2016
            • 618
            1st week June 63
            67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
            • Arland D.
              Moderator
              • July 31, 1980
              • 426
              Thomas,
              So your post showing an engine assembly date of May 15 is for a car with a build date of early June having a lead time of about three weeks.
              Danny,
              Do you have any body build date for the car with the July 15 engine assembly date to help establish a lead time?
              My July 5 engine build date is for a car built about three weeks later.
              • Michael J.
                • January 27, 2009
                • 7140
                20180321_152550.jpgFirst week of May build date.....
                • Mike M.
                  • May 31, 1974
                  • 8399
                  mike: appears to be a long leg R to me. mike mccagh
                  • Michael J.
                    • January 27, 2009
                    • 7140
                    It is, the proposed theory here was that after the second week of May is when the short leg R started. Danny says: "i went back to F05 and F04 they all had long legged R." And this: "Arland, with my search looks like late May and on they started using shorter legged R anything under May and earlier they all used the longer legged R."
                    • Thomas S.
                      • February 7, 2016
                      • 618
                      Correct
                      • Danny P.
                        • June 30, 2002
                        • 344
                        Michael, i ,am finding long legged on F06 and F07 in some case's it looking to me the short legged R are bouncing around through out the year.
                        • Michael J.
                          • January 27, 2009
                          • 7140
                          I see, so your original hypothesis is no longer valid and the appearance of the short legged R is random throughout the '63 MY, never mind then.
                          • Danny P.
                            • June 30, 2002
                            • 344
                            i,am doing a search don't make a case of it Michael enjoy your evening ???
                            • Mike M.
                              • May 31, 1974
                              • 8399
                              [QyUOTE=Michael Johnson (49879);921709]20180321_152550.jpgFirst week of May build date.....[/QUOTE]
                              the subject of your post was"1963 stamp pad with SHORT leg R", yet your photo example shows a LONG leg R. you post is confusing to say the least. mike mccagh
