Starting after sitting for a while & Underbody pic - NCRS Discussion Boards
  • Grahame M.
    • November 7, 2011
    • 225
    Hi All,
    A couple of quick questions:
    1. Its been around 4 months since i last started my car, do i need to prime the oil pump?
    2. The pic below was taken after i changed the footwell splash shields, are they option codes?
    I'm assuming the PB is Power Brakes and i think UA6 is the alarm system?
    Appreciate you help.
    Cheers
    Grahame
    69 427 Tri-Power 4 Speed
    Black on Black
    • 15640
    Re: Starting after sitting for a while & Underbody pic
    Originally posted by Grahame McCann (54038)
    Hi All,
    Cheers
    Grahame
    Grahame
    1) No
    2) You are correct. PB = Power brakes, UA6 = alarm system
    Cheers
    • Larry E.
      • 1702
      Grahame>I always put a little gas(In my case pure Av Gas>100LL) down the front vent tube of carb.
      This will ease the strain for the Starter. Larry (Always starts right up)
      Larry
      LT1 in a 1LE -- One of 134
      • Grahame M.
        • November 7, 2011
        • 225
        Thank you Terry and Larry for your quick responses.
        Hopefully everything goes well, i can start it up and get it down off the stands.
        Thanks again.
        Grahame
        Black on Black
