Headlight problem - dimmer switch extinguishes all Headlights - NCRS Discussion Boards
  • Grant M.
    • August 31, 1995
    • 448
    I have a 1965 convertible and when I press the dimmer switch on the floor, instead of illuminating the high beams it turns off the low beams. The switch, as I recall (it's been 35 years) is a replacement/reproduction from one of the suppliers (CC or Ecklers). The headlight bulbs are incandescent (one or two may be original T-3s), not halogen (which I believe draws more current).
    Can anyone suggest a troubleshooting path?
    Grant
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: Headlight problem - dimmer switch extinguishes all Headlights
    The switch is probably faulty. Install a new one and you should be good to go. If not, then the high beam wiring is faulty. use a clip lead to jump the wiring at the dimmer switch from the 12v supply to both the high and low beam wires. Easy test.......If the lights still don't work then the next area to check is the bulkhead connector on the firewall..
    • Jeffrey S.
      • April 1, 2004
      • 133
      rock auto has a number of the switches for reasonable money if you need a new one. hope this helps
      • Jimmy G.
        • November 1, 1979
        • 977
        Exact same thing happened in my 60 in July Bad dimmer switch They are cheap and not too hard to replace
        • Grant M.
          • August 31, 1995
          • 448
          Thanks Stephen. I'll check the switch first.
          • Grant M.
            • August 31, 1995
            • 448
            Thanks. I'll check the switch.
            • Grant M.
              • August 31, 1995
              • 448
              Thanks. I'll be checking the switch first.
              • Norm B.
                • 360
                There is nothing quite like the feeling you get on a moonless night in Northern Ontario when you hit the high beam switch and your headlights go off , so here is an old trick I learned from back in the day of driving GM buses up there. If that switch has not been used regularly or in quite a while try working it hard a few times. Because of where they are the contacts tend to collect dust and dirt and sometimes doing that clears it. It may not be the ultimate fix but it often gets it working again.
                Golf is for those who can't play​ hockey.
                • Grant M.
                  • August 31, 1995
                  • 448
                  Norm, moonless night, northern Ontario, two-lane highway, 'moose' warning signs and no headlights...I know of what you speak. I almost hit one (moose) in my 78 Formula Firebird heading west in 1979, and that was with working headlights...
                  Thanks for the tip. As I noted in my original post, it's not the original switch but a (35+ year old) replacement, that's almost never used (I don't drive the car after dark). So your tip may work. I'll let you know...
                  Grant
