Battery going dead - NCRS Discussion Boards
Battery going dead
  • Scott S.
    • March 1, 1979
    • 747
    Battery going dead
    I recently had a problem with our 1966 BB Corvette. The battery was constantly going dead. It turned out to be a faulty headlight dimmer switch, I changed it out and the problem went away.
  • Gary B.
    • February 1, 1997
    • 7078
    Re: Battery going dead
    Scott,
    Very helpful info. That sounds like it might have been a hard to diagnose problem.
    Gary
    • Gary B.
      • February 1, 1997
      • 7078
      Duplicate. Can’t delete.
      • Leif A.
        • August 31, 1997
        • 3655
        Scott,
        Glad you were able to find/identify your little parasitic draw and solve the problem. Just out of curiosity, do you use and employ a battery cutoff switch?
        Leif
        • Scott S.
          • March 1, 1979
          • 747
          Yes, I have a cutoff switch, not the issue
          • Stephen L.
            • May 31, 1984
            • 3162
            Do you use the battery cutoff switch???
            • Leif A.
              • August 31, 1997
              • 3655
              Didn't imply that it was. If the battery cutoff switch were employed on a consistent basis, the parasitic draw would not be able to drain your battery...that was my point.
              Leif
              • David H.
                • June 30, 2001
                • 1567
                Battery cut-off switch use would also keep an electrical problem from being discovered and corrected. Knife cuts both ways.
                Dave
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  I use my battery cutoff switch to prevent potential fire due to shorting in a circuit, but more importantly, it prolongs the life of the clock mechanical cycling of the contacts in the spring winding system, which cycle about every 2-3 minutes, 24 hrs a day........ or about 500 cycles per day!
                  • Gary B.
                    • February 1, 1997
                    • 7078
                    Stephen,
                    Good point. 500 cycles /day => 182,500/year => 1,825,000 cycles every ten years. That has the potential to kill it.
                    Gary
