Re: Shell Rotella oil
I wrote my oil article initially for vintage Corvette owners, but later stated that it applies to any vintage spark ignition four-stroke automotive engine with SLIDING SURFACE VALVE TRAIN COMPONENTS!!!
It was not meant to be advice for modern engines of any kind!
I'm disappointed that some OEMs are not longer recommending API service categories, but have their own specs like GM's Dexos. It may be more about another revenue source rather than solid technical issues, since using the name requires a licensing fee.
For modern engines I can only recommend what the OEM recommends, at least during the warranty period. After that you can do what you please, but it should be based on solid and reliable sources, not Web forums or You-Tube videos and the like.
I'm not sure if SJ is a current API category, and I believe using "obsolete" categories is a violation of API licensing agreements, but you can find out by downloading the current oil spec chart from www.api.com and reading the API 1509 document and appendices.
