54 6cyl torque converter mounting to flywheel - NCRS Discussion Boards
  • Norman N.
    Infrequent User
    • November 1, 1979
    • 14
    Am I wrong to assume the torque converter attachment brackets that mount 6 places on the face of the converter be in a flat plane so they will mate to the flywheel plate? My brackets are at a slight angle away from the centerline of the converter. This means that if the bolts are tightened down fully, the flywheel becomes distorted at each mounting hole.
  • Tony R.
    • April 19, 2017
    • 201
    Re: 54 6cyl torque converter mounting to flywheel
    I don’t know if this will be helpful but here is a photo of mine…
    • Norman N.
      Infrequent User
      • November 1, 1979
      • 14
      Thanks Tony. Noticed you only have 3 brackets whereas I have 6. Could you possibly take a photo from the side to see if there is any angle to the brackets?
      Norm
      • Tony R.
        • April 19, 2017
        • 201
        I am on a trip to see my daughter this weekend but can when I get back. In the meantime I will look through my other photos. Also, there are a few 53-5 folks on here that might know.
        • Tony R.
          • April 19, 2017
          • 201
          I have a photo of the flexplate and it sure doesn’t LOOK distorted at the attachment points.There is one attachment point at about 4:00 or 5:00 in the photo where , given the lighting, I think any deformation would be visible. As an aside to this thread perhaps someone can tell me if I should have six of the attachments.
          • Chris S.
            • January 1, 2000
            • 1067
            Tony
            Yours is a passenger car and or truck fly wheel
            Same for the OP
            Here is my experience the passenger car and truck are larger in diameter
            The Corvette is smaller
            I will measure them tomorrow - I have several in the shop
            The larger fly wheel will have problems with the starter
            It will not engage !
            The passenger car / truck starter is different
            I will post up a photo of the two
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Chris S.
              • January 1, 2000
              • 1067
              This is an engine I did for 1954 #21 - Real deal - note the starter (starter and solenoid are Correct)
              This is another engine I did and it is a truck engine
              Note the starter angle and position - see how the solenoid is tilted
              Hope this helps
              • Tony R.
                • April 19, 2017
                • 201
                Cthis - Thanks!
                • Norman N.
                  Infrequent User
                  • November 1, 1979
                  • 14
                  Chris, Thanks for the photos of the flywheel. I have the one with the cutouts. Getting back to the problem of the Torque converter mounting brackets, If you place a straight edge across them, are they flat or do they show some angle NOT parallel to the face of the converter?
                  Norm
                  • Chris S.
                    • January 1, 2000
                    • 1067
                    I will pull the convertors I have out - Yours look correct - I dont see any issue - Let me look at mine
