one piece oil pan gasket - NCRS Discussion Boards
  • Bruce W.
    • June 30, 1997
    • 360
    Hey guys, Does anyone know where i can get a one piece oil pan gasket that is black for a small block Fel pro makes one but it is blue?
    Thanks Bruce
  • Harry S.
    • July 31, 2002
    • 5332
    Re: one piece oil pan gasket
    It's black, just looked at one I have in the package. I used this on a 63.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    • Mike M.
      • May 31, 1974
      • 8402
      according to the manufacturer, the product harry posted does not fit a 63 327 chevy engine. nor a 57 283. maybe harry typo'd his post. i didn't check with manufacturer to see if they have one piece gaskets for the early abc's. mike
      • Harry S.
        • July 31, 2002
        • 5332
        Getting the correct gasket has always been a headache.
        Please take a look at ..... https://www.forums.ncrs.org/showthre...ighlight=mahle
        • Owen L.
          • September 30, 1991
          • 883
          I chose a Mahle for my 427 but don't have my car judged, so if you go the one-piece route, be prepared to swap the stock bolts for 1/4" longer ones. I was able to force the gasket using the stock bolts but it was a struggle getting the threads engaged.
          • Gary B.
            • February 1, 1997
            • 7054
            I just had installed a one-piece Mahle oil pan gasket on my L79 and like Owen says, the stock bolts were too short to feel secure that enough threads engaged. So we used the longer bolts that came with Mahle gasket. The Mahle gasket is just that much thicker than the original GM gasket.
            Gary
            • Robert P.
              • October 19, 2019
              • 317
              Gary, did you end up using part #OS32458
              Bob
              • Gary B.
                • February 1, 1997
                • 7054
                Bob,
                Yes.
                Gary
                • Bruce W.
                  • June 30, 1997
                  • 360
                  Gary, did the gasket cure the leak?
                  Bruce
                  • Gary B.
                    • February 1, 1997
                    • 7054
                    Bruce,
                    You must be misremembering. My motor was just rebuilt for the first time. With a motor with 82k original miles, nearly everything leaked. Now nothing leaks.
                    Gary
