Change After Market/Non-OEM Disc Front Brakes to Original Drum Brakes on '64 Roadster - NCRS Discussion Boards
  • Rob V.
    • July 31, 2002
    • 261
    Hello All--
    For several reasons I wish to convert the "after-market/non-OEM" front disc brake modification that a prior owner installed on my 1964 Roadster, back to the "original" GM/Chevrolet drum brake set-up. 1). What parts would I require; and, what supplier/vendor might have these parts? (I want to use GM/AC-Delco/Chevrolet components; and preferably, no reproduction parts. Good used or restored parts would be "ok" as applicable.) Thank you in advance for your assistance/response(s) to my questions.
    Rob
    Rob
    SPEAK YOUR MIND, but ride a fast horse. -- Anonymous
  • Rob V.
    • July 31, 2002
    • 261
    Re: Change After Market/Non-OEM Disc Front Brakes to Original Drum Brakes on '64 Road
    No responses, so I will attempt to list the required parts that I can determine: '64 Power Brake Booster (complete assembly); '64 Master Cylinder Mount; '64 Power Brake Master Cylinder (with bleeder); Proportioning Valve(?); '64 Front Brake Line kit. NO CLUE what is required for front wheels/front brake assemblies--help please. Anyone know of a complete kit for what I am trying to attempt?? Thanks in advance.
    Rob
      • 15678
      There are guys on the Corvette Forum who are converting '63-'64s to front disks. Generally you remove the entire steering knuckle from the car that includes all the drum brake hardware... pretty much as this assembly arrived at St. Louis and replace it with the disk brake knuckle and disk brake hardware.
      So what do they do with these removed knuckles with all the attached drum brake hardware? There's not much of a market for them, so go over there and you can probably find some cheap.
      • Rob V.
        • July 31, 2002
        • 261
        Hi Duke--
        Thank you very much for the information!! I now have a good understanding of what will be involved with the restoration of the front brake system. I will check for the parts locally, albeit, two (2) of my good sources have closed their businesses; then I will check out the Corvette Forum as you recommend. Again, I very much appreciate the information and recommendation. Happy Friday!
        Rob
        • Rob V.
          • July 31, 2002
          • 261
          Mr. Paul Young--
          Received your PM; "thank you very much!" I am very interested. Unfortunately, your phone number did not come through. My cell number is: (720) 775-8027. Rob
          Rob
          • Rocco S.
            • December 21, 2013
            • 176
            Rob,
            Look in the latest issue of Driveline. I just saw an ad for someone selling a 63-64 front drum brake set-up.
            ROCCO SCOTELLARO
            1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
            • Rob V.
              • July 31, 2002
              • 261
              Thank you very much Rocco; I will look for the ad! I truly appreciate you bringing it to my attention! Rob
              Rob
              • Rocco S.
                • December 21, 2013
                • 176
                Rob,
                The ad is on Page 31. Seller is George Barker. The setup does not include drums. But it may be a good start.
                ROCCO SCOTELLARO
                • Rob V.
                  • July 31, 2002
                  • 261
                  Hi Again Rocco--
                  That was a HUGE help! Thank you. (I was on page 25). I will contact the gentleman, as I really want to get this brake restoration accomplished. Rob
                  Rob
                  • Rob V.
                    • July 31, 2002
                    • 261
                    To All--
                    I thought I would "close the loop" on this post. I was extremely fortunate, and was able to source all of the "required" 1964 front wheel drum brake parts locally, thanks to our Rocky Mountain NCRS Technical Advisor, Mr Gary Steffens, Corvette City, (303) 762-8388.
                    I very much appreciated the responses and support that I received.
                    Rob
