Aluminum valve cover restoration - NCRS Discussion Boards
  • John B.
    Infrequent User
    • December 1, 2002
    • 9
    Hi everyone. I searched "valve cover restoration" and the most recent thread I found was almost ten years old. I wondered who is doing an NCRS-quality restoration these days. Thanks in advance.
  • Joe R.
    • July 31, 1976
    • 4551
    Re: Aluminum valve cover restoration
    Give John DeGregory a call. His aluminum finish is art!
    JR
    • Michael M.
      • February 1, 1993
      • 604
      I would try vapor blasting the aluminum first to see the result. Vapor blasting is usually all is needed to restore aluminum.
      • Kenneth B.
        • August 31, 1984
        • 2091
        I agree. less is better.
        • Gary B.
          • February 1, 1997
          • 7054
          JR
          • Bill M.
            • 1328
            Mike
            is vapor blasting the the same as dry ice cleaning?
              • 43258
              Bill------
              They are not the same. As far as which one is "gentler", that I do not know.
              • Bill M.
                • 1328
                Joe
                thanks i wanted to get my 67 intake done but i am concerned with the length of time for the process. i drive the car until just about the first snow. i dont want to leave the motor open all winter. There is some one on LI whe does dri ice cleaning. Ill have to speak to them to see how it works.
                  • 11678
                  I had a 1963 B-W transmission case done by vapor blasting. There is a guy somewhat near who has been doing it for many years, and his work is exceptional.
                  Turnaround was a couple of days. He know what he's doing, and usually does motorcycle engines and similar, though he has done some Corvette parts prior to mine.
                  Here is a photo of the transmission after I assembled it.
                  I had him do a couple of midyear valve covers too, but no picture here. I can post one later if you wish.
                  They look great.
                  • Bob I.
                    • November 9, 2006
                    • 265
                    Originally posted by Bill McMorrow (15609)
                    Mike
                    Vapor blasting is
                    a surface refinishing process used to clean and restore surfaces. Instead of dry abrasive media (used in sandblasting), it uses a combination of water, compressed air, detergents with finer and gentler media to remove oxidized metal and corrosion.
                    • Bill M.
                      • 1328
                      Bob and pat
                      thanks i will give it a shot
                      • Michael M.
                        • February 1, 1993
                        • 604
                        Bill, as Joe stated not the same. I feel that vapor blasting is the best procedure to restore aluminum back to its original appearance.
                        • John B.
                          Infrequent User
                          • December 1, 2002
                          • 9
                          They look great.
                          Hi Patrick--if it's not too much trouble, I'd like to see a photo of the valve covers. Not just for me but for the record...Thanks.
                            • December 1, 2005
                            • 195
                            John DeGregory did mine...they turned out perfect!!!
                            • Bill M.
                              • 1328
                              Terry is that the process that john uses?
