Alternator pully size - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    Looks like the alternator on my 1966 427-425 Corvette has finally died. Replacement alternators come with a smaller pully than on the original. If I recall the high performance (reeving) engines had a larger pully. Does one just buy what is available and then swap the pullies out. Does it turn into PIA job or is it relatively simple?
  • Mike T.
    • January 1, 1992
    • 569
    Re: Alternator pully size
    Ted - if the existing alternator on your 66 L72 is the original #1100696, you could have it rebuilt but if you do go with a remanufactured alternator, it's an easy thing to get the existing pulley off your current alternator and swap it onto the remain alternator.
    I did that recently on my 66 L72, the alternator on there had been rebuilt by John Pirkle many moons ago and it just died.
    In the interest of time, I 'borrowed' one from my project 65 L78 and swapped on the pulley from the L72 alternator.
    I typically use an air driven impact wrench to remove the large nut up front. If you don't have access to an impact wrench, a hex wrench to hold the shaft and a large crescent wrench will do.
    I'm going to send you a PM regarding your L72.
    Mike T. - Prescott AZ.
    • Ted K.
      • August 31, 1994
      • 337
      Thanks good information. I'll check out the forum.
      • Paul O.
        Infrequent User
        • April 20, 2022
        • 26
        Do you guys have part #s for the pulley and the fan? I have correct alternator for my 66 L72 but having trouble confirming right pulley and fan. Thanks
        • Leif A.
          • August 31, 1997
          • 3650
          Paul,
          GM Part Number:3829193 with power steering
          GM Part Number:3829387 without power steering
          For '64 - '67 all alternators that did NOT have an integral pulley used the same alternator fan. I don't have a part number as the alternator came to the factory as a complete assembly. Picture below of what you want for a pulley.
          Leif
          • Paul O.
            Infrequent User
            • April 20, 2022
            • 26
            Thanks Leif... that's a big help.
            Paul O
