Source for 68 Std energy absorbing Steering Column?? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I am restoring my steering column on my 68 and see that the upper and lower shafts of the two-piece energy absorbing feature can slide freely. The metal cage section is not collapsed but is cracked and is two pieces. My understanding is that this column is spent and needs to be replaced.
    In looking on line, I am not seeing many options to replace the shaft section / metal cage assembly. Other than EBay, I am also struggling to find a supplier of the entire column itself. I also think, but can be completely wrong, that the 67 and 68 columns are identical designs, which could open my options to source from the C2 world as well.
    Does anyone have a suggestion or recommendation on how best to repair the column or who to call for a suitable replacement?
    Thanks!
    Pat
  • Mark F.
    • July 31, 1998
    • 1592
    Re: Source for 68 Std energy absorbing Steering Column??
    Originally posted by Patrick Nolan (48743)
    Does anyone have a suggestion or recommendation on how best to repair the column or who to call for a suitable replacement? Thanks! Pat
    David Sokolowski at (310) 329-5334. Member #22609
    thx,
    Mark
    • Patrick N.
      • March 10, 2008
      • 954
      Thanks Mark! I will give David a call
      • Keith B.
        • September 15, 2014
        • 1600
        the plastic shear pin has been broken. this is done by the people installing the other type of steering box who need to shorten the shaft
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11363
          Keith, Do you know something we don't know?
          Either way, the mesh can be repaired. See the following pdf in the Sticky DoRD thread. Then link to Update Page....
          This file... Note its titled "Tele", but it shows how to repair a Std column also.
          https://www.forums.ncrs.org/attachme...4&d=1613208356
          Rich
          P.S. Yes 67 and 68 columns are the same, except early 67 uses a different lower bearing and plastic spacer. Differences in Date placement also, iirc
          Blueprints in the DoRD link also. HERE
          • Patrick N.
            • March 10, 2008
            • 954
            Thanks all for the comments and resources -much appreciated!
            Rich, like many others have already said- thanks for this amazing document! I will post a pic of the steering column when I have a chance to see if it seems salvageable.
            Thanks!
